Re: Farmall A Manual Lift
Posted by gene bender on February 02, 2010 at 15:20:15 from (207.177.56.220):
In Reply to: Farmall A Manual Lift posted by Paul Wald on February 01, 2010 at 17:57:59:
No such thing as a set of hand lift levers that are universal for this tractor. All lift levers are made for the implement that is used. For instance there were three different type of levers used just for the cults. The plow had different levers as so all the other attachments for that model.The exhaust lift were also made for that implement. For instance the two-way plow had a total of three levers. The single bottom plow had two. If your tractor has two levers side by side and the same length with one behind them it is for the cultivators that were available with exhaust lift. Give better detailed description and i can tell you which implement they are for.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
