Re: Removal of final drive on left side of Farmall B
Posted by jfay on February 02, 2010 at 15:22:08 from (98.216.126.38):
In Reply to: Re: Removal of final drive on left side of Farmall B posted by Paul Brueggeman on February 02, 2010 at 05:01:30:
Paul if it is like my 140, there is a lock bolt on the inside of the brake drum you need to loosen. Once you do that, drive the differential shaft out through the brake drum towards the outside of the final drive with a hammer. You need to remove the bearing cover on the outside of the drive first of course. The drum should come loose after a few good hard hits on the differential shaft.
