Re: problem torque disassembly
Posted by D Slater on February 02, 2010 at 15:33:26 from (72.65.151.239):
In Reply to: Re: problem torque disassembly posted by jim in ny on February 02, 2010 at 15:16:20:
If you have the clutch cross shaft out of the way. Screw a slide hammer or long 3/8 coarse thread bolt and something heavy to slide on it in the hole in the front of clutch shaft and bring it out. Also if you have the top plate removed from the clutch housing a prybar at rear of pto drive gear will move it out. Be careful and only pry below the gear teeth. Hardened teeth will chip off if pryed with not very much pressure. Learned that the hard way years ago.
