Re: farmall a temp and trans problem
Posted by gene bender on February 02, 2010 at 16:03:50 from (207.177.56.220):
In Reply to: farmall a temp and trans problem posted by kj n tn on January 29, 2010 at 19:25:11:
There is no thermostat in the Farmall A. Your block is plugged. Junk builds up in the lower block where coolant flows at the bottom of the sleeve. I would remove the radiator and the lower outlet. Then back flush with compressed air and water. You can look in the block and see if that clears up the small nickel sized holes. I have used a stiff wire and got them clear you will find a lot of junk in the lower passage its just what happens after 60pluss yrs of bad water.
