Re: problem torque disassembly
Posted by paul smta on February 02, 2010 at 16:16:41 from (68.117.10.58):
In Reply to: problem torque disassembly posted by jim in ny on February 02, 2010 at 14:46:24:
I had the same problem with mine you should be able to see all the bolts.Use a rubber hammer or mallet and beat the snot out of it equaly on all sides,this is a common problem if the hytrans fluid has a lot of moisture.There are only 3 bolts that hold the ipto drive bearing cage to the clutch housing.
Good luck.
Paul.
