Posted by Lew in UT on February 02, 2010 at 17:45:56 from (173.84.179.1):
In Reply to: Shift Lever M posted by lbm on February 01, 2010 at 18:31:22:
this is a problem with all the older tractors and especially old agzeler transmissions in trucks some will disagree. but hear go's if you are a bit good with acetylene torch take a electric chromium type hard surfacing rod brake the flukes of the out side , grind the Warren part and grind it slightly whear it is worn to clean it up,then take the torch and build the wrong places up with the chromium hard rod, then grind to the same size as the rest of the lever that has not worn the sides are all that you need to be concerned about. you will never have to worry about it agen.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
