Re: farmall 400 to 450
Posted by Charles E. McNelly on February 02, 2010 at 18:41:27 from (72.18.77.250):
In Reply to: farmall 400 to 450 posted by 555 on February 02, 2010 at 18:13:19:
Same block, same stroke, same cam, just order the overbore kit for the 400. Takes you from 4" to 4.125". You will have 281ci. when finished just like the 450. If you have the 362174 gas head on your 400, your motor will be the same as the 450 gas period.
Charles
