Re: farmall 400 to 450
Posted by D Slater on February 02, 2010 at 18:56:43 from (72.65.151.239):
In Reply to: farmall 400 to 450 posted by 555 on February 02, 2010 at 18:13:19:
If you look at kits for sale you will see the 4-1/8 or 450 size is what they sell for both engines now. Only thing you need to match up is the piston pin size. 400 engines up to engine serial # 163807 used a rod and piston pin size about 1.31 inch. Later 400 and 450 used a 1 inch pin and a rod with a smaller end and bushing. Buy piston set to match your rod size or use adapter bushings to go from large pin to small, or use late rods. Aftermarket will have sets to fit both without any changes though. Later pistons with small pins that IH had along with the rods were lighter than big pin parts and the engines were a little smoother. Aftermarket and maybe the pistons case IH sells now have piston weights that sometimes don't match the original type parts.
