Re: H carb.
Posted by rustyfarmall on February 03, 2010 at 06:33:03 from (209.152.78.140):
In Reply to: H carb. posted by Agman55 on February 02, 2010 at 17:33:15:
Theman said: (quoted from post at 06:32:39 02/03/10) There is also a felt seal for the choke shaft that rarely is noticed. It is captured by a thin brass retainer in the bowl casting. If your felt piece has a hole in it, that's where it goes. A picture would help a lot, but I don't have one.
Yes, that is where that little round piece of felt goes. I usually just throw it in the spare parts bin, but if the choke shaft seal is really bad, then I cut off a small piece of that felt and work it into the original brass ringed seal.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
