Re: Farmall H belly pump questions
Posted by sflem849 on February 03, 2010 at 14:41:18 from (69.197.84.192):
In Reply to: Farmall H belly pump questions posted by NawlensGator on February 02, 2010 at 18:02:03:
Janicholson said: (quoted from post at 14:52:27 02/03/10) Yes, no problem. If you use it one way, there is no need for the diagram, just hook up the cylinder push hose to the right side pressure elbow as in the illustration, and the upper retract hose to the bottom of the reservoir. The regular control rod will then work as designed. There will be no need for a second valve as in the illustration, and the upper part of the cylinder acts as additional reservoir space, and the hose prevents the need for a vent. Jim
So there is no need for a vent? I know my one ways just have a pipe plug in them.
