ryanwheelock said: (quoted from post at 11:25:55 02/03/10) Anyone know much about the belly pump upgrade. Found this on a website, www.farmall-h.com under lift-all.
The kick-off pressure is increased, an improvement package (15261-E) was made available which permitted increasing the kick-off pressure of the earlier pumps. Lift-all pumps of early manufacture were set to kick off at 450 to 500 pounds pressure in the system. Later Lift-Alls are set to kick off at 750 to 800 pounds pressure. These higher pressure units can be identified by a yellow figure 8 painted on the outside of the reservoir.
Anyone heard of this before?? Anyone ever upgraded their pump??
The major part of the upgrade was a new center section of the pump housing. The end clearance of the pump gears was not adjustable on the early pumps. The new center section was narrower and used shim gaskets to set the clearance on the gears. Early pumps may not be able to create enough pressure to kick off at the higher pressure settings.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
