Re: hand cable on 674
Posted by jimb2 on February 03, 2010 at 17:14:45 from (99.240.236.11):
In Reply to: hand cable on 674 posted by RVS on February 03, 2010 at 09:28:42:
Hi RVS, the hand brake cable can be changed from the outside. There is an upside down U support bracket bolted to the frame and a rubber boot under the bracket. Inside the rubber boot the cable will have an eye bolt on the end that fits into clevis with a pin in it. Remove pin and cable can be removed. See www.caseih.com then go search for parts 674 Brakes.
JimB
