It sounds like something is weak in the ignition. From what you're saying it only happens under load. I've seen this happen with bad plug wires on a car or a bad plug. Since you're backfireing out of the stack, I'd say for one reason or another, your ignition is cutting out, and allowing unburned fuel to enter the exhaust. Then when it fires again, all that fuel is ignited causing your backfire. I'd start with a general tuneup. Go for points and condenser first and inspect your cap. You may have some bad plugs or even the wrong plugs, or maybe some bad plug wires. I remember when I was on here years ago, seems like some guys were putting in resistor plugs and causing ignition issues. I remember it's important to get the right plugs and plugwires on it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
