Re: Need some Red Tractor Advice to start baling
Posted by mike321 on February 04, 2010 at 16:13:03 from (64.198.86.189):
In Reply to: Re: Need some Red Tractor Advice to start baling posted by The tractor vet on February 04, 2010 at 14:40:32:
I have a 7220 Magnum and a 956 deere discbine 15 ft cut and I can cut 15 acres per hour. That is an acre every 4 minutes. I use alot less fuel than you do to cut hay per acre and alot less to rake either. I use a 16 wheel rake at about 8 mph. I could cut your field in two hours lol. You never stated how big your tank is..... I could drive a 2000 miles with a diesel truck if my tank was bigger. You never stated how much fuel per acre or hour you burn. I can cut 175 acres in a good day. How about you???? How about a gas 856 vs a diesel 856 we used have both and the gas was always out of fuel.Maybe a 706 is a different story. We used to pull a NH 489 with a farmall 450 and you did good to get 5 acres an hour and it burned about 2 gallons per hour. I think I am more efficent that you per acre. Plus I have A/C, powershift and air ride seat.
