Re: M Water Pump Rebuild Help
Posted by glennster on February 04, 2010 at 17:29:09 from (99.90.9.153):
In Reply to: M Water Pump Rebuild Help posted by neblinc on February 04, 2010 at 16:32:33:
randy!!! where ya been hiding at ??? havent heard from you in a while. looking at the nut, figure what size socket it will take and then zip on down to your local napa and get a 4 wheel drive spindle nut wrench. it should get right in there, if need be you can grind the tangs down on the socket a little to get in there.. heres a link to what you are looking for. they are used to remove the spindle nuts on the 4wd front hubs.
