Re: 1466 steering pump
Posted by pete 23 on February 04, 2010 at 18:44:59 from (173.87.0.197):
In Reply to: 1466 steering pump posted by joe 1971 on February 04, 2010 at 16:49:09:
The new tube seal should be considerably longer than the used one. If it looks like it is too long it is probably the correct one. There has been some problems over the years getting one that will compress sufficiently. I have added a 0-ring on a couple to increase their length. Just slip it in first and put seal on top of it .
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
