Re: splitting a Farmall M
Posted by glennster on February 05, 2010 at 06:00:15 from (76.217.99.179):
In Reply to: Re: splitting a Farmall M posted by 47farmallM on February 04, 2010 at 18:40:55:
if you are going to re-ring it, block the back end up, drop the front steering, then take the radiator out, remove the front steering bolster and frame rails, then pull the motor. if you just split it in two pieces, its gonna be harder to handle with everything attached to the engine.
