I took the carb off last night because when I pulled the drain plug on the carburator it only ran for about a count of two and then went to a trickle. I took the carb apart and clenaed it out then put it back together, put it back on the tractor and there was no flow at all! So I took it back apart and tried to blow where the fuel line enters and I could not get any air to pass. I took the float off and the needele was stuck. I got it unstuck and cleaned it, replaced the needle and the float and it almost imediatley became stuck again. So tonight I am going to rebuild the carb. Is there a certain make of rebuild kit I should look for? Also does a rebuild kit come with this needle valve? Thanks for all of your help I will let you know what happens.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
