Re: Farmall H belly pump questions
Posted by Janicholson on February 05, 2010 at 06:28:24 from (199.17.6.222):
In Reply to: Re: Farmall H belly pump questions posted by sflem849 on February 04, 2010 at 14:56:07:
Sflem,
I am not sure what you mean by one outlet.
If on the tractor, supplying pressure to something, it usually means that it is single acting setup. If hooked to the business end of a double acting cylinder, the far end port (which may be located at the same end) will push out and suck in air as the cylinder moves. If the port is plugged, air pressure builds up and declines in that part of the cylinder. If it is free from oil, it can wear the bushing and packing gland on the ram. If it is vented with a paper breather, it can bring in moisture laden air. If it is used as an extended reservoir bu being connected to the reservoir (but at the drain port) it will just act like a larger reservoir, and lube the cylinder ram end. Jim
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
