Re: Reversed Operation Tractors and Implements/Equipment
Posted by Larry Hardesty on February 05, 2010 at 06:48:53 from (74.38.151.80):
In Reply to: Reversed Operation Tractors and Implements/Equipment posted by Harold H on February 05, 2010 at 06:33:05:
Hay sweeps. Used to do it alot in the Sandhills of Nebraska to sweep up loose hay for stacking. My aunt still has two Farmall Super Cs that have been reversed. With all that weight over the back axles, they could push a lot of hay. In the early 60s, my grandfather even had a Super A reversed, and it could push a lot of hay. Not much loose hay being put up in the Sandhills any more
