Re: C more power
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Robert on May 01, 2000 at 04:20:25 from (209.90.238.62):
In Reply to: C more power posted by Tim on April 30, 2000 at 22:55:21:
Hi Tim: I have never heard of such a hook-up where did you get your info? You say that it looks the same as the other engine and has more HP without the increase in the casting? I would like to learn more about this. You will have to have an incresae in the sleeves, pistons, rods, different cam shaft, and probably a heaver crank-shaft. You would have to have a better cooling stystem for all that heat.
Tim, speak to me what do you know that I don't? Thanks! Bob
Post A Followup
: Re: Re: C more power
