Re: H oil pan bolts
Posted by old on February 05, 2010 at 15:12:32 from (4.245.11.22):
In Reply to: H oil pan bolts posted by Zachary Hoyt on February 05, 2010 at 14:57:44:
Yep as Cowman said but you can also use 5/16X1/2 inch in most. I would take the time to clean out all those holes with a tap to make sure they are in fact empty since some one may have gotten a little carried away and broke a bunch of them off in the holes and if that has happened it means you will most likely need to drop the pan to pull them out
