Posted by Zachary Hoyt on February 06, 2010 at 13:06:03 from (74.33.226.232):
Thanks for the help. I got 14 bolts and tooth washers and they all screwed in nicely. I could spin most of them in with no ratchet till their heads touched. I guess someone had the pan down recently and left the bolts out, because when I went to install the belly pump a few days ago those holes were all full of dirt and rust and had to be cleaned out. I borrowed a camera and took a picture of a small disconnected line running to the air cleaner. Should I repair that, and if so will rubber gas line work or does it need to be metal? I also took a pic of the rubber I put between the alternator and the valve cover as Old suggested. Does that look okay like it is? Thank you all very much for all of the help you've been over the last couple of months. Zach
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
