Farmall A Head Torque
Posted by Roger46 on February 06, 2010 at 15:21:39 from (70.209.11.141):
I know that there was a revision to torque the Farmall C head to 80 ft-lbs instead of 65, but is that the case with the Farmall A's as they are the same engine basically? Roger
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
