Alright fellows here we go. I rebuilt the carburetor, Put on a new coil, cleaned and re-gaped the plugs, replaced the plug wires and the coil wire, I checked the distributor cap for moister and cracks.. it looked good and there was no moisture. I started the H up and it was not to long and it started the same thing all over again..Should I replace the fuel line and petcock? I emptied the sediment bowl, then when I went to refill it it just trickled out through the petcock into the sediment bowl. By this time I was aggravated and went into the house to ask all of you what you thought I should try next. After I sat here for a little bit I think I should have looked in the tank for junk floating around in there. Could that cause the symptoms I talked about?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
