Flow divider Pilot valve - 2606
Posted by bc on February 06, 2010 at 21:02:24 from (71.158.221.179):
Hi, after a year and a half of jacking around with the minimal power steering, I pulled the flow divider and pilot valve assemblies today.
Haven't started on the pilot valve yet but have them on the bench.
I unscrewed and removed the safety valve stop on the back of the flow divider however the safety valve assembly won't come out even while trying to pull it with needle nose pliers. The drawing shows an oring which could be hanging it up but it still won't pull out.
I unscrewed and removed the lockout assembly from the front of the flow divider however the flow divider valve and spring won't come out. It has a couple flat edges that I can get needle nose pliers on but it hangs up even with the end of the body. The drawing doesn't show an oring inside of it.
The adjusting lockout assembly screws in and out like it is supposed to. The flow divider valve can be pushed in almost 3 inches and works back and forth freely. Maybe it is OK.
Question is how do I remove the flow divider valve from the front and the safety valve from the back? I was just going to clean them up, check them out, and stick them back together.
Or should I call the flow divider valve good and move on to the pilot valve and pull it apart?
Thanks for the help.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
