Re: On Off Switch on Cub
Posted by ScottyHOMEy on February 07, 2010 at 07:09:59 from (64.222.221.197):
In Reply to: On Off Switch on Cub posted by Qual on February 07, 2010 at 07:00:05:
The one on the mag serves only to ground the mag to stop the motor, or to break the ground connection to allow it to run. The wire connection is between the stud on the side of the mag and the pole on the bottom of the switch. Ground is reached through the switch body.
The two pole for the battery igntion makes or breaks the circuit providing power to the coil.
