Re: governor mystery?
Posted by bc on February 07, 2010 at 11:16:56 from (71.158.221.179):
In Reply to: governor mystery? posted by mike paulson on February 07, 2010 at 10:40:38:
The tractor carbueration system is a gravity feed and governor operated system. Just like on a Briggs and Stratton gas engine. The throttle goes to the governor.
A car and truck engine is driven by a fuel pump and the carbuerator has an injector/fuel accellerator inside the carb. The throttle goes directly to the carb.
They operate under different principles. Once you understand the separate operating theories, it makes it easier to troubleshoot problems. Too many people apply car engine troubleshooting techniques and symptons to tractor carbueration techniques and symptoms and it doesn't work the same.
