Re: IH engine inter change.
Posted by sflem849 on February 08, 2010 at 06:21:27 from (69.197.84.192):
In Reply to: IH engine inter change. posted by M Diesel on February 07, 2010 at 15:13:43:
mkirsch said: (quoted from post at 06:10:35 02/08/10) If the gas start diesel is scaring you off, you'd be much better off looking for a newer machine.
Regardless of which crawler it is, though, I'm pretty sure that there's no easy bolt-in diesel engine for it. Anything you put in will require extensive modification. By the time all is said and done you'll have more in it than if you went out and purchased a newer dozer.
Same thoughts here as well.
