Re: putting on 1100x16 tires on a IH 1066
Posted by Lee in Iowa on February 08, 2010 at 07:52:26 from (66.172.198.5):
In Reply to: putting on 1100x16 tires on a IH 1066 posted by Eric Wieland on February 07, 2010 at 16:59:29:
Don't cut off the stop, bad things can happen. The steering arm can kind of go over center and hit the wide front when you turn short. Then when you try to staighten out it can't go any where. I put a wide front together out of parts and pieces I had laying around and one end didn't have a stop. When I bolted the saddle at the back of the wide front to the frame I was too cheap to buy the special tapered washers that go above the frame rails. Those bolts worked loose when I had the heat houser on so I didn't notice it. Then the steering arm went too far on the end without the stop and when I tried to straighten out the force of the power steering broke the wide front loose from the tractor. It had enough force to break one corner off where the bolt goes through on the wide front and broke out two holes on the upper bolster of the tractor. If you're not far away I have 2 wheels for 1100x16 I would trade for wheels for for 1000x16 probably what you have.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
