Re: IH engine inter change.
Posted by RN on February 08, 2010 at 09:11:18 from (96.60.79.133):
In Reply to: IH engine inter change. posted by dave anderson on February 07, 2010 at 15:13:43:
Check engine bay size - a 560 diesel and later family may fit and bolt up to transmission. 560 straight diesel replaced the gas start MD, 400/450D engines- bolted to same transmisions, back of engine bolt pattern same.this would handle TD6 and couple other numbers. Older brother ran across this swap when he was pushing cats years back, noticed engine was same as fathers 560 tractor and asked- was told swap was done because straight diesel was available cheaper and wasn't subject to as much abuse by student operators that didn't shut off earlier engine on gas setting and then messed up worse on restarting. Filters in box in construction shop did fit dads tractor;^). RN
