Re: identifying tractor
Posted by glennster on February 08, 2010 at 14:56:54 from (76.217.99.179):
In Reply to: identifying tractor posted by washingtonMark on February 08, 2010 at 06:15:35:
a couple quick checks, the cub gas tank and hood are all one piece. the super a will have a separate hood, gas tank and front grille. the cub serial number plate is located on the front lower casting where the steering shaft enters the casting. the cub also has a flat head engine, the spark plugs sit on the top of the head, no valve cover. the super a will have the spark plugs at an angle on the side of the head, also will have a valve cover.
