Mine was plumbed to come out at a freeze plug, heated in a tank-style heater, and return through the fitting where the temp sensor goes. This worked well (half an hour to an hour of heat with temps in the zero to 20 degree range), but was less than ideal with respect to loss of temp sensor. We tried removing one of the inset square-headed plugs, but didn't manage to loosen it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
