Re: Super MTA engine overhaul
Posted by pete 23 on February 08, 2010 at 18:28:00 from (173.87.0.197):
In Reply to: Super MTA engine overhaul posted by Ruegers on February 08, 2010 at 18:00:47:
Forget the felt, for sure don't put in on inside. Position the seal so it will ride on a good surface on pulley with lip toward engine. Original seal had a felt incorporated in a double seal arrangemt and actually had the leather lip seal lip toward outside. Not sure of your gasket set, but some contain the felt for the water pump.
