Re: $1374.02
Posted by El Toro on February 09, 2010 at 12:50:59 from (74.103.74.58):
In Reply to: Re: $1374.02 posted by Mark W. on February 09, 2010 at 09:05:57:
If you have a deep socket that will just fit inside that spline on your clutch disc and in the
bearing in your flywheel, that will work too. That's what I used on an A in 1976. Put a light coating of oil the output spline so it will slide on easily. Hal
PS: I don't see any torque specs for the clutch cap screws, but I think 35 foot-pounds should be ok. Take a look at your new clutch disc to see if it has a direction on it. Like toward flywheel.
