Posted by Andrew Z on February 09, 2010 at 16:28:42 from (64.252.113.90):
In Reply to: Farmall C engine posted by Cory S. on February 09, 2010 at 15:09:26:
You need to bore the block in order to fit that size sleeve. The biggest piston that you can fit in 113 block is 3 1/8" piston. The 123cid will fit the 3 1/4" piston without boring the block. You have three options either get the right sleeve kit for that C block (3 1/8") or bore the block to fit the sleeves you have or get a 123 cid block. If you look for anouther block you need one out of a late Super A, Super C, 100, 200, 130, 230 etc. Personally i would try and see if you can exchange those sleeve you have for the right one, or sell that one you and by the correct one. Good luck
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
