Re: need a new clutch for my 856
Posted by pete 23 on February 09, 2010 at 16:32:58 from (173.87.0.197):
In Reply to: need a new clutch for my 856 posted by IH-Mitch on February 09, 2010 at 15:50:11:
You will get a lot of different opinions on what clutch is best for the 856. I prefer to stay with the four pad disc and std duty pressure plate as the 856 clutch pedal can get fairly hard to push with the heavy duty ones due to the configuration of the pedal. I have caught it in the neck both ways,from you should have put in the heavy duty, or why the heck did you put in the heavy pushing son of a gun. I also feel the four pad can be tweaked for better release ,(less gear grinding) than the six pad ones. Lot of different suppliers to choose from including this site.
