Posted by tractorsam on February 09, 2010 at 16:59:51 from (99.192.70.12):
In Reply to: Farmall C engine posted by Cory S. on February 09, 2010 at 15:09:26:
For the C-113/C-123 blocks there are two sizes of bores (in the block) for the sleeves. Most (including your C) have a 3 5/16 diameter where the o-rings seal. The 354898 block (R1 throught R4) has a 3 7/16 diameter bore where the o-rings seal.
Your options at this point are either to return the kit and get the correct one with the smaller outside (and inside) diameter sleeves. Have your current block bored out by a machine shop to accept your larger sleeves. Or to search for the 354898 block. If you choose to search for the newer block beware, unless I'm very much mistaken the 100/200, 130/230, 140/240 all use blocks with a 3 5/16" lower opening diameter. So you would be looking for a block from a '53 or '54 Super A or Super C.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
