Re: need a new clutch for my 856
Posted by The tractor vet on February 09, 2010 at 17:11:49 from (75.19.124.251):
In Reply to: need a new clutch for my 856 posted by IH-Mitch on February 09, 2010 at 15:50:11:
Well Pete is some what correct but i use a 6 pad with a standard Pressure plate unless you have hdy. assist or if has a hair dryer on it then i will go heavier . If is set stock to 15% the standard one is more then enough. As for a really good clutch and PPa i have always used Hy Capacity.
