Re: 1086 International
Posted by pete 23 on February 09, 2010 at 20:01:32 from (173.87.0.197):
In Reply to: 1086 International posted by xib on February 09, 2010 at 18:09:21:
At what rpm are you talking about. The gov action on these models is next to nill at say below 1200 rpm. Notice how it doesn't smoke black much when it is idleing and you open the throttle, due to the walking beam type gov internal linkage. This can be mostly overcome with internal adjustments but these would best be done on a test bench or hooked to a dynamometer. It requires adjusting the droop screw and or cam nose angle. Of course, your governor may be worn out if it doesn't have good response at higher rpms.
