I have same Pic . But What I have is chisel Mark on Crank Gear That when on Compression TDc Does not Line up with anything. But Single Dot is 2 Teeth South, as for other side of Cam Gear at the upper left there is a chisel mark there that will not line up with straight with Mag drive gear I have not removed crankshaft or cam shaft there the way I found them I have never heard engine run or have any idea as to how it ran at this timming mark setting. Thanks
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
