Re: 1066 Gear Shift Boot - Again
Posted by Allan In NE on February 10, 2010 at 05:37:33 from (148.66.88.254):
In Reply to: 1066 Gear Shift Boot - Again posted by Michael Sheik on February 10, 2010 at 04:49:58:
I left that boot off of my tractors.
However, I can sure feel the cold air coming up thru those levers in the winter time.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
