Posted by Andrew Z on February 10, 2010 at 17:12:54 from (64.252.113.90):
In Reply to: more hp from super m posted by jdetig1 on February 10, 2010 at 17:00:28:
You can change the carbs venturi or drill out the metering jet, yet the hp that you will gain from this is minor really. Anouther factor that at least i look at if fuel efficiency will go way down if you mess with the carb much. As it is your going to be using more fuel then stock. However if you play with the carb and fine tune the timing you may be able find a few horse. The best thing to do is if you have access to a dyno, get it on it. Then you can really find all the power it has.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
