Re: F20 engine tools
Posted by Nebraska Kirk on February 10, 2010 at 18:16:14 from (207.91.4.134):
In Reply to: F20 engine tools posted by pete 23 on February 10, 2010 at 16:06:56:
IH nut said: (quoted from post at 18:06:56 02/10/10) Hello, I am looking for a puller to remove the flywheel from an IHC F20 engine. Also, a puller to remove the crankshaft from this engine as well. If anyone knows of these pullers and where to find them it would be greatly appreciated.
kind regards,
Wayne
Original tools will probably be hard to find and expensive if you did find them for sale.
A flywheel puller is quickly made with couple pieces of heavy angle iron and some threaded rod. Use the angle iron to span the flywheel housing, drill holes in the angle, insert the threaded rod through the angle iron and into the three threaded holes in the flywheel, thread nuts onto the rods and use them to pull the flywheel off.
