Re: International 140 rear rims
Posted by Daniel H. on February 10, 2010 at 18:43:14 from (66.226.34.159):
In Reply to: International 140 rear rims posted by william jones on February 10, 2010 at 05:56:45:
The round loops work best with carriage bolts. On the left side you can use standard Ford or MF bolts since the wheel center is stamped steel. On the right, the cast wheel is too thick for those so you need longer bolts. McMaster-Carr has longer ones on line, but I don't remember the length I used. You should get Grade 5 bolts, which are harder to find in carriage bolts. The Carrier bolts will not turn when you tighten them, so you only need one wrench.
