Re: 806 3rd arm
Posted by Weldon K on February 10, 2010 at 19:14:26 from (98.16.28.151):
In Reply to: 806 3rd arm posted by bjd49 on February 10, 2010 at 12:30:04:
I assume that the "third arm" you are referring to is the top link of the three point hitch. 806 has Category II three point hitch. Any top link for Cat. II will work, be it original IH or aftermarket. A catalog I have shows Cat II top links available as follows :
min. 21" max. 31"
min. 20" max. 30"
min. 27" max. 37"
If the shortest that you can get the one you found is 31" , then it may not work in all situations .
