Re: OT? PTO generator
Posted by Marty from MN on February 10, 2010 at 19:29:14 from (71.34.13.145):
In Reply to: OT? PTO generator posted by Machine249 on February 10, 2010 at 19:07:42:
Unless you need a lot of power, (i.e. running a milking system and bulk tank cooler in a barn) you would be better off with a purpose built unit. Most 3000 to 5000 watt generators are in the 5 hp range and will run the essentials in a house. Why run a 40 Hp tractor? It will use a LOT more fuel since it won't idle down when not under load.
