Re: generator on farmall A
Posted by gene bender on February 11, 2010 at 06:11:36 from (207.177.56.220):
In Reply to: generator on farmall A posted by Bill Shaver on February 11, 2010 at 05:47:18:
Thats been done for many yrs to make them charge more. If you think the rate is too high move the third brush and it will lower the rate. If you are still using the mag you only need a charge rate of a couple amps. You mite want to use an OHM meter to see if all the componets in the charge system have a good ground even the control box on the steering post all need ground for the system to work.
