Re: farmall ih no 5 side delivery rake info
Posted by Stephen Atkins on February 11, 2010 at 08:53:28 from (71.222.203.150):
In Reply to: Re: farmall ih no 5 side delivery rake info posted by chrisinsoky on February 10, 2010 at 20:37:39:
chrisinsoky
You might make sure the bushings on the ends of the bars are not wore too much. It has been ten years since I used one. Also keep it greased. Good luck with it if you get it.
steveormayr
