Re: Best plug for H
Posted by Andrew Z on February 11, 2010 at 11:26:00 from (64.252.113.90):
In Reply to: Best plug for H posted by ryanwheelock on February 11, 2010 at 11:12:37:
Champion D 21's or Autolite 386's are a hotter plug. The D 16's are on the colder end of the heat range. During the summer run a heavier oil such as a straight 40 or 20w-50. The plug extenders you talk about are designed so the plugs elextrode do not go as far into the combustion chamber as normal. This means there is less chance of them being covered in oil. These help some also, worth a shot they are cheap. This will help some till you get a rebuild in there.
Andrew
